Tiller to remote conversion
  • Tiller to remote conversion
    Hello,
    I am wanting to convert a 2009, long-shaft, electric start and non-power trim 20HP from tiller to remote. Can you please provide a parts list and cost for the conversion as well as the control box and any harnesses needed for the conversion?
    Domenic
    Pittsburgh, PA
    If this is a F20ESH model then use
    6AH-48501-00-00 Remote conversion kit
    6AH-61350-00-00 Steering Guide kit, for remote steering
    6AH-82590-10-00 Engine wire harness
    703-48207-17-10 703 Side Mount Control Box with elctric start
    (2) MAR-CABLE-xx-SC(replace xx with length cables needed) Throttle and Shift cable, requires two.
      Hello,
      So the 6AH-82590-10-00 wire harness has a female 10 pin I think, cause the 703-48207-17-10 remote control has also 10 pin.
      Thank you.
      Aron
