New 115TLRC Install
  • New 115TLRC Install
    Just purchased a new 2004 115TLRC two stroke and I am installing it on a Mako 17 that had a 1980 Johnson on it. Here is a rigging list. Does anyone see anything else I might need.
    Thanks Rd
    704-48205-14-00
    "704 BINNACLE CONTROL BOX (Elect Start, Power trim models)" 262.95 197.57
    704-48293-00-00
    704 single binnacle control box spacer 4.95 3.38
    6YR-W0035-E0-00
    "MULTI FUNCTION TACHOMETER KIT (Works on 2 stroke and 4 stroke engines includes Digital Tach, Trim Gauge, Hour meter, overheat and oil warning indicators, includes 22 FT Harness) 1994-2004 Models" 356.95 232.05
    704-82570-07-00 recommended for Binnacle and Flush mount control box's "SWITCH PANEL ASSEMBLY 10 PIN (With Warning, Choke, Stop Switch)" 147.95 108.73
    688-8258A-50-00 USE WITH 10 PIN SWITCH PANELS ENGINE TO SWITCH PANEL ELECT HARNESS (10 Pin) 16FT 70.95 55.98
    6YR-W0035-92-00
    "2.8 GALLON OIL TANK (2 stroke oil injected models, includes elect harness) " 368.95 259.90
    ABA-CABLE-13-GY 13FT Original Yamaha Cables 30.95 Qty 2 23.56
    That should be all you need unless you need a prop, good job.
