Nipple fittings
  • Nipple fittings
    I have a 99 t9.9elhx. pulled the power head yesterday and am cleaning the water jackets.18 years in salt water, lots of build-up but motor still runs like a watch.my question is what is the procedure for removing and installing the brass nipple fittings on side of head? Thank you for any thoughts or suggestions
    They are a push fit, no thread. Fragile so difficult to remove without breaking them, main risk is them snapping off leaving a core in the head. Suggest pour boiling water over everything and then squirt plumbers freeze over just the nipple and wiggle back and fore with a mole grip.
    If they look ok and you can clean the crud out (pipe cleaner useful here) then I would not try to remove them at all.
      See also:
      http://www.yamahaoutboardparts.com/f...l-th29068.html
      Good Luck!!
        grab them with vice grips and twist back and forth.
        Yamaha sells them if you break it.
        no need to remove the head,'
          Nipple fittings
          Thanks guys.i haven't twisted the wrenches in forty years. Retired now, and having fun with this amazing little motor.ill give it a try this afternoon.
            Mole grip = vice grip
            "...two great nations, separated by a common language...."
              Nipple fittings
              Warmed up the head next to the wood stove, then chilled the nipples with ice. Fittings came out with medium force using vice grips.thank you for the suggestions.
                Originally posted by Robster52 View Post
                Warmed up the head next to the wood stove, then chilled the nipples with ice. thank you for the suggestions.
                I hope this is a motor you're talking about, and not your girlfriend......
                  If in Florida are those Miami Vice Grips?
                    Heaven help us where our minds wander to with a simple phrase! I wondered about that from the title.
                    Dennis
                      Dirty minds think alike.
                      There was a young man from Bikini
                      Who spilled gin on his weenie
                      Not to be uncouth
                      He poured on some vermouth
                      And slipped his old lady a Martini
                        We call them nipple rings here in the states. Fittings must be a Brit term.
