External Grounding strap
  • External Grounding strap
    I am trying to find out what size bolt/screw is used for "engine side" of the external grounding strap on a 1999 200hp. I believe the strap is used for Anode grounding or just general grounding of the lower unit. it is at the top of the lower unit and the bolt/screw goes into the side of the"upper" lower unit.... pics....HELP!!!!!
    Mike
    OBTW...how do I get "attachments" to work? Would like to post a couple of pics...
    You can use Postimage.com. Upload pics there and then copy the "hot link for forums" down below pic. Paste the link here in the body of your message.
      A model # would help greatly looking up the part...
      M6 x 1 pitch (metric) is often used thru out the engine as well as that ground bolt. Lenth, you'll have to measure...
      1997 Angler 204 CC, 2006 F150 TXR
