Yamaha 2005 tilt trim-what r ball bearings used for in tilt trim?
  • Yamaha 2005 tilt trim-what r ball bearings used for in tilt trim?
    In disassembling my 2005 Yamaha tilt trim, I noticed there were 5 ball bearings floating around loose at the bottom of my tilt trim. however, there are 6 holes at the bottom of the piston. does this require 5 or 6 ball bearings? what are the ball bearings used for? much thanks for your help with this.
    see item 15(ball bearings) on this schematic. https://www.simyamaha.com/category_s...rt-category=60
      Your motor uses a "tilt within a trim" cylinder. It has single ram and a "cylinder within a cylinder". The inner cylinder also functions as a piston of sorts. The inner cylinder/piston has the main piston/ram located within.
      The inner cylinder is the part with the six spring loaded balls in it. As the cylinder rises (during the trim function) when it gets to the full up trim position the six balls move outward into a groove that is machined in the inner wall of the main cylinder. Those balls move into the groove and lock the inner cylinder/piston in place.
      Capiche? Not so easily explained.
        ABSOLUTELY, EXCELLENT EXPLANATION. THANKS a bunch. that is very interesting...Bob
          Interesting. I assume there is some sort of back pressure that forces the balls to move back and unlock the cylinder. Guess that would be the only way?
            The 64,000 dollar question is where is original ball 6? I believe you said there were 5 in the bottom of the cylinder.
              rolling across the floor somewhere if it was mine
                Where you won't find it till six months later!
                1997 Angler 204 CC, 2006 F150 TXR
