2017 Yamaha F150xb prop chatter
  • 2017 Yamaha F150xb prop chatter
    I’m currently using a 14-1/4x17P reliance series prop non sds version and getting prop chatter . I thinking about ordering the new version reliance series SDS with out the space washer . Will this new version of reliance series SDS prop eliminate The prop chatter ?
    The Reliance with SDS should reduce or eliminate the prop rattle/chatter.
      600-700 bucks buys a good bit of Marine gas....bump the rpm up 100 and it goes away. Or it should....
      Edit: 600-700 buys a good bit of gas for an F150....
        Thank you for your reply .
