Can it charge
  • Can it charge
    I was hoping someone could tell me if my outboard I inherited from my father could charge a battery for a fish finder and electric downriggers. I don't know much about it, and sent the info to Yamaha which told me that it is a 2008 F15MLHG production date November 2007.
    They also said it could not charge a battery. Does anyone know if it could be added?
    What is the complete ID of the motor? Begins with the number 6.
    The F15MLHG was not offered here in the US. I suspect that you are from some other country.
    I am guessing that your model did not come with a rectifier/regulator and related components, which on a US model F15CMLH are alternate parts. More than likely the same with your model. You can buy and install alternate parts so that your motor can charge a battery.
    2006 and Later F15CMLH Yamaha Outboard ELECTRICAL 2 Diagram and Parts
      Sorry, I should have mentioned that I am from Canada. Here is a picture of the complete tag attached.
        The Yam Can parts catalog shows the same alternate parts for the installation of a r/r.
          So in theory if I get the rectifier regulator assembly it should be able to charge?
            No theory, get the parts and it will charge....as noted above.
            Happy Fishing
              as long as you have a working lighting coil and hook up the R&R properly
