6HP flusher recommendation
  • 6HP flusher recommendation
    I wanted to know if anyone has a recommendation for a muff flush that fits a 6HP outboard. The motor is on my sailboat in the water and not easy to always remove it to a horse and insert in a bucket of fresh water. Every muff I have reviewed is too big to fit the small space for the water intake opening..
    The 6 HP model should have a port that can be used to inject fresh water for flushing.
    ABB-FLUSH-JD-00 is the part number of the device that screws into the flush port.
      Thanks for the reply but I could not find any reference in the manual or locate where that part would connect within the unit.
        Is your question about what device to use to flush the motor or about where to connect a device? Or are you simply looking for a small set of muffs that will work?
        What is the complete model of your motor?
        6 HP two strokes have been available from 1986 thru 2000.
        6 HP four strokes have been available from 2001 thru 2017.
          The model is F6LMHA, 2017 4 stroke. I hoping to find something to allow flushing without removing the motor off the boat.
