156 Communication Error / not starting
  • 156 Communication Error / not starting
    I have 08 350's with newer power heads. My STBD engine will not start. There is 13 volts at the motor, trim/tilt work, with key on you can hear the fuel pump whine, and if idling on the good motor the non-running motor will shift into reverse and neutral and forward. This is also reflected in the control screen for this motor. I have had a "STBD 156 / Eng-R/C Communication" fault. I also discovered a blown 60 amp Isolator fuse and replaced it but when you hit the STBD start button nothing happens. The fuse has not blown again but I have not gotten the motor to start yet. I have jumped the STBD motor from the port motor to rule out a bad power or ground. Any ideas? I have ordered a new dual start button assembly to rule out a bad button.
    my recommendation.
    fix the R/C issue.
    may be as simple as an R/C reset.
    may have a helm ECU or engine ECU issue.
    your going to have to have the 2.23 yds and the breakout box to isolate the helm or the engine.
    you should also have a flashing yellow at the helm.
      Thanks Rod
      Any pointers on how to do TH RC Reset?
        select the correct screen on YDS and hit enter.
        then follow the instructions.
          I think if I owned one of those motors I would definitely have an updated version of YDS.
