2006 Yamaha 90 HP 2 stroke stalling at idle
  • 2006 Yamaha 90 HP 2 stroke stalling at idle
    Good afternoon let me start with some background on this engine. This engine is mounted on a glastron 16 foot fiberglass boat. This boat belonged to my grandfather and when he past away he left it to me. This engine has not run in 7 years and has just been sitting. I started with the basics I cleaned the old fuel out of the fuel tank, cleaned the carburetors and tried it. I couldn't get it to run. It would fire with a shot of quick start and if I played with the butterflies enough I could keep it running but it was running very poorly. No throttle response it just bogged. So I elected to replace the fuel pump remove and clean the carburetors again and I replaced the fuel lines to everything. I also replaced the primer ball and the clip and that attaches the fuel line to the engine. I still had the same problem but it had slightly improved. I decided to add a water separating fuel filter to the unit and added more fresh gas. I have finally gotten it to run so I elected to put it in the lake and give it a good run thinking this would help with everything. It has great throttle response now and runs fantastic at anything above an idle. However if i return to idle after 15 to 20 seconds it stalls. It refires right away but if I dont increase the throttle it will stale again. Could anyone possibly provide me some insight as to something I may have missed or could try? Is there an idle circuit in the fuel system somewhere I am missing?
    Thanks for any help you can provide.
    Michael,
    did you disassemble the carbs completely and clean in a carb cleaner?
    did you remove all of the old gas and clean the tank before adding fresh fuel?
    if so might be time to clean with a heated sonic bath cleaner.
    did you reset the pilot screws to factory spec and do a link and sync after reinstalling the carbs?
    1st thing I always do is check compression check to see if there is a problem with a motor I just came home with
      I did not remove the pilot screws on any of the carbs. I'll have the look up a breakdown for the carburetors. Obviously I missed those unfortunately. Also you seem to be very knowledgeable on this. Could you clarify for me what a link and sync is? Thanks for the help.
        Just looked at the schematic. I missed the pilot screws. Looks like I have some more work to do. am i correct in reading remove them, clean them then reinstall to bottomed out and back out 1 and 1/4 turn?
          service manual has a procedures to set all of the linkages properly.
          it makes sure all cabs are set exactly the same opening and also the timing.
          pilot screws are for the idle mix setting. they have to come out to clean everything properly
          it has all of the spec for your motor also
          just cleaning the screws is not what needs to be cleaned.
          the jets and all passages need it also
            https://www.boats.net/catalog/yamaha...406/carburetor
            Pull jets 20 and 23 and check / clean them. If you can't see light thru them, their NOT clean..
              Yep I got those ones good and clean. I did miss the pilot circuit so I believe 99yam40 has me on the correct track. Thank you for the advice. I have to remove all the carburetors again anyway to check the pilots so I will be rechecking everything again in those as well. Thanks again.
                My C90 very similar to yours was cutting off a idle....I removed each idle mixture screw from top of each carb, remembering the turns out from lightly seated for each one....sprayed carb cleaner in each orrifice then blew it out with an air hose....replaced and set each screw....fixed the problem right away! ....Been running this motor since new in 1999 and only had to do this procedure once....give it a try
                  Thanks for the info. I absolutely will be doing this next chance I get to work on it.
                    Yep, it worked for me....a simple 10 minute job....must have been some trash in one of those passages. Fuel/Water seperater type filter is a great idea here!..
