F90LB High Idle
  • F90LB High Idle
    when I come into a dock or slow down the engine stays at high idle and I cannot shift out of gear easily. After I turn engine off and restart she is fine again. what would be cause of this? engine is a 2017 F90LB with the tiller handle. I am thinking throttle position sensor or idle control valve maybe?
    2017 Yamaha F90LB
    Warranty ? Need to hook it up to a laptop and I doubt you have the software. No reason to guess.
      yeah I have an appointment next week. I was just wondering if there was anything small I could check before hand. I am 1.5hr away from dealer.
      2017 Yamaha F90LB
        All speculation at this point. Where are you located?
          newfoundland, canada
          2017 Yamaha F90LB
            I would make sure the throttle cable/linkage all returns to the proper places when throttled back,when the problem shows up.
            sticking IACV might be the problem, or the ECU keep is keeping the timing or IAC set to high idle for some reason
