Toggle switch on electronic pack on engine 1989 140 hp
  • Toggle switch on electronic pack on engine 1989 140 hp
    On 1989 140 hp with engine cowl removed bolted to port side of block is an electronic unit possibly ignition & it has toggle switch on it. Is this a kill switch
    I would think it is the oil pump e switch to pump oil if the autmatic part does not work due to low oil in remote tank
          See page 75
          https://www.yamahapubs.com/outboard_...8626-07-95.pdf
