Originally posted by Offshore_life
View Post
(I'm not claiming to be an expert) My experience tells me it is likely to be a check valve that is allowing pressure to leak by, or perhaps an internal leak past the ram piston seal. Hopefully they change that seal too as it is probably only $10 or so and it should be right there and easy to get at.
I am confident that you probably won't have additional problems.
Cheers!
Leave a comment:
