Yamaha F115TXRZ fouling plugs
  • Yamaha F115TXRZ fouling plugs
    Actually 2, a F115 and a LF115. Both motors doing exactly the same thing. After a long storage, both motors were fouling plugs. To the point that they would start to miss after about 45 minutes of cruise running, 4000-4500 rpm's. If I clean the plugs they run again for same amount of time, clean, repeat. All 8 plugs black fouled, dry, no oil. I have changed one coil that was bad. I drained all gas from both separate tanks and filled with fresh. The only other thing I can think of is I had purchased aftermarket fuel injectors and maybe they are causing the issue. I have cleaned the old original fuel injectors and will try them next. I am getting 5800-6000 rpms wide open. So a little confused why they would run so rich. I read some about throttle position sensor and was wondering if that is readable with the Yamaha diagnostic software I have.
    Any help would be certainly appreciated.
    Gene
    put the original cleaned injectors back in and see if that solves the problem.
    monitoring the fuel pressures to make sure they stay in spec would also be a good thing to know.
    hard to see how both motors would be doing the same thing. would need something common between them.
    fuel is the only thing I can think of
      Yeah, fuel and the injectors I replaced. I drained all the fuel, separate tanks and filled with fresh. So I am hoping the injectors are it. Thanks for the input.
        Originally posted by finaticfishing View Post
        ... The only other thing I can think of is I had purchased aftermarket fuel injectors and maybe they are causing the issue. I have cleaned the old original fuel injectors and will try them next. I am getting 5800-6000 rpms wide open.
        Gene
        Hi Gene,
        When you say that you cleaned the [original, factory] fuel injectors, did you send them out to be professionally cleaned and flow checked or did you do something yourself?
        I found [ mrinjector()us ] has a good service at a good price for top feed fuel injector service. I suspect you already realize that cleaning and resealing your fuel injectors is tantamount to when we used to rebuild our carbs. It is all about fuel atomization....
        I go too far offshore to use aftermarket anything...
        If its got teats or tires, you bound to have trouble with it....
          Update. So I replaced all the plugs with new. I also flush the original Yamaha fuel injectors that I still had forward and backwards with cleaner. Ran the boat yesterday. All the plugs are showing normal firing, no soot/carbon buildup. So I think the aftermarket fuel injectors are not compatible for some reason.
            Just curious, where did you get the aftermarket injectors from? What brand are they?
              ...and what did you pay for them?
              I am curious too as to have your old (factory original) ones professionally cleaned should be less expensive than new aftermarket.
              BTW, thank you for the update and 'cure'.
              Cheers!
                [IMG]http://www.yamahaoutboardparts.com/core/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgwAAABOCAYAAAB MiU5BAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJc EhZcwAADsMAAA7DAcdvqGQAABovSURBVHhe7Z1NjBVF94fv+89/hywVWbjwRUxY8CWwEQVZgCBsUARiIiABEgSFmKAJAguJJkBCjK OSSAICCQEU3QAiLBQVXAjytTCo6MIFMi7V9bw+RR+oqanqrp77 wYzze5JO31td3VV1uqrOqVPV3f/p+YeGEEIIIUQJ/1fshRBCCCGSyGAQQgghRCUyGIQQQghRiQwGIYQQQlQig0EIIYQ QlWQbDHv37m1Mnjy58dV***Uh7YM0SKtqaxeW/rvvvluExOE48fojk9w0/k2YvMq2lStXurj9lc+2bdvceexT/PHHH4158+a5eN9//30ROrBADuSv3dS5JyHIcfHixVn36MiRI+5aMaxviW1V17b8l7X BWBw/jXCjvOS3Dlx7/fr1jSeeeKKp6+Qw2PqOsnuEzDZv3lz8u1WniG/tk404sXOJy7kmc+riiRMniqO9IZzjxCM+53F+SJ1rxmhX/g3OyW1zXDvWdkmD/MXKX0WWwfDjjz829u3bV/zrHBMnTmwsW7YsuYly6KyoNAONOXPmRO8n28yZM4tYfckpz/Llyxv3339/46OPPoo2UtizZ0/j999/d+k98sgjRejQpu49obN56aWXGj///HMRkob7tn379uJfX3755Re3j6U9btw4d6wdUE/C9J599tnGjRs3XH5zFTLG6SuvvNK4dOlS4/HHH+9zHTr4/nTOwHnkA6Pq3waKC5m9/PLLRUijsXHjxsaHH37YGDly5G05Egf5+u3Z6t9nn312W+Z//fVXY8uWLX2ULvWPcI4Tj/icx/k+da6Zoh35N+ycnDZHP8m1Yzz11FMuf++8804RUgPew1DFihUr eqZPn94zadKknjNnzhSh7YM0SKurq6sI6Sy56XO8UzLpD+SNez dQaFZeueU5fvy4i7to0aIi5A4XLlxIHhtIUE7y2W7q3pPu7u6e fwyu2/0BW6qdIGsrh20xuBf9rac5+Y/F4X8qTcpo5eN3GXbtdevWReMiK473t76RZ873ZRwLG8ik7tHcu XN7lcHa7aZNm4qQW8TarF0T+RrIn2uyGXYvCfPvj92Xw4cPFyH 510zRjvwD4cTLaXPkgfMtXqqOWx0K70kVlR4GrNuffvqpsXTp0 iKkGiwhXCGhu5f/sXAhWgkW9GOPPeYs8XCUaCPdV1991e1FPf7pYBvvvfee+10lw1 WrVjUuXrzoPIWMtFJwnx566KHi393n3nvvdR4X+OGHH9w+Bp5X RpN4Kt5++213XsgLL7zgyk4Z2zE9MVhBFnj5Zs2aVYQ0Gjdv3n T7+fPnu72BF5A65I+sv/nmGyd35Gsg/2eeecZd10bp3333nRu5L1mypNf94bx77rmn8cknnxQh+ddM0Y7 8Q26bw4OBh4LzqXOkmWLatGkufb/8OZQaDCh2GgTGwqhRo4rQan777TdnZOCGMeOAPf8JbzXM/8TmagjjmA/5YE7J5peYy2mlu480zSiy9NlIkw7G4OYSHio0KorNtbHxO+Zaj 5XDrmXXBjpsfvvpxNIIG4OVg4bNHBubdXhcy5+jI15VY6qLL5+ q8sR4/f***YdA/TW5cw6NFvdfOBVBHNx4frmQS5iOyQX5mwyRja2ZQA52jVjdyk3 HqKpHgHwIt7lQtnbcEwNl+sEHHzQWLlxYhMShQ6KD2717d2PYs GF***/8um31mXIgIwYed4tUfn3Onj3r9iijMkyB+J2z3aMQu9dAnaDPB Oox4b68gHpn951zw+OQ094htx4RTt5svRB1mXoKflrWLv7++29 3zAdZYCQ+/PDDRcgtJX7+/PmsacKUkWl6yqa5bB+LO3r06F5KPPeaKdqRfyO3zWEk7Ny5s/Haa68VIWlmz57tDJewPymj1GBgNEYGfCsoBwRGpoEKj6Kxik94 jkDbAZWafCAkm7NlLgfrzTr8VsDcJenQ6ZAGMiRNk0EK5ORbiD avxXl+o6VhM3pjbswvB50K5aCjJgzst80Fc9yfz7M0CAuVFsbd +++/79Jgnm3ChAkuDun4c3TE4/xYZ9UKysqTAmvdrPEdO3a4RvH***+7Rrp27VoXbqCYkOfXX3/t7pWVi/tAWc1QMuz+0uEQlzyxZoLOljbjz0lSt0wuddMBqzPEjdUjrs1/OiCrC+wxrLgndTqDHJDd1q1be3X0KY4dO1bZwV2/ft3tkd/w4cNd/pEr86/0O3fLaLh8+bLbY3SmOHfunNvHOn4fZEUcXznlQB3nXoLVF+qaQ X1GTsSxdkhd8NthbnuvW49Im3pMPPJGn04fRVzrvzif/HFvfbgW6eAFzIH45MPiW/lich8zZozbm5Fi9zGmc+x86lida9almfxDbpvDa4Bxzj4H60PN 8M3h/4t9H6hM3Pg33nijCKmHGQ1UQjpRGl5dY4FOlC0Gllxddu3a5Ro LlpqfDzp6KjWLu+rkLwVyW7NmTS9DizTo7DFaYmlQaVHOdAiMS s19tmjRIncdZIirHYgXkydpUDFZ+EclM8VuCpKKSzmpqF1dXb3 SYDEN8XERWsVEVtx/Sxe4n5xPxTSQG4qQcufANWLQ8fjXNcgPW1ieKsj3qVOnnNzpyC BWn3FbwosvvthLwTEyfO655xqnT5/uFR7eX+RH50g63BNrsDRIynrlyhUXVjcdwLtXVo+4NpCu36GMH TvW1RnKX9XRQN170mrCekYbwNhiYRadZRWp/NeFNoLMaEemCKvIiYMxBCiL3A7d4qF0x48ff7ve++2M9mztmHa IHLjvnFunvdetR/QNftpg/ZIfTl+E8UB8g4EO/Pe//3X7MugXre1WeXLA0s0xzsyLVDbtBHWuGdLO/DeL1S8zqnKIehio1FQmOquczqZdmFUd2+riW3lhA6cDBzrsVuF 38mDWpN9wfL744gt3jDksvxHym4rGMSx4ykFlYhQbloN51EOHD vU634dGD+F8nqUBFsfwO3FAYdNhMRomL0A+MOCqRpOGjWDCrew Jif5iUxPILFWfKeOXX37ZJ/9ldd+/vyZL7rE1QvB/Q7PpQFiPUCLIPryGPxLNoZP3xIfykf+wnhHOfWMUm0Mq/2z0IzHoD8z1bhuGG30fcn7rrbeKmAOTBQsW9GrHtEP6BdqnGT6 Q097r1iNk6l8TA5Z0uQ9hWoT5dHd3uz33twyUrT0VgLcwxzAbS AyG/HMP6nhO+hgMFBKLkgoRdlZ1MPc/mGuY/4TnYlZ1bKuLWeUIB++Jv1mj6YRVl8IaEXNXYf6uXr16+5iVY8S IEW7fH6ZMmVL8uoMpoipWr17t9tQROlfmL3F71rmvKKHYPc01O OpAh4WLG6rqM3UfY5nRLWViLrYONoqsotl0YqAguCb1hfl/7k8dOnlPcuG+pQzskFT+2ehHYqAMYwYGHsgywzvEDOcy/vzzT7cPjchmiE3LWb9g/QTUae/9rUd2nx588EG398FLEcPc7zFCZZtbDzkPcvozU5Rl+QD/msgmNDLZQjqR/1ZAG6uzrrCPwYB7hsoWWt+m/NnzH8Gl8I0FXFwIiz3UNRpaDeViBBFuAwXcj2HeCBsoYCXjcqQ R4K2ho+A/UxJ0MoMRGimLuxgJUT9xhVNPzNBoFe1Ih7aE0YbxxjWpL7TfTn U4rcA6yU5j01vhljsSfPTRR93eXOwpKB+KYyDfk3bWoypPQgh5 YRojpWzN6IoN8Gx6waYbzFiM6Rw7H8OwzjWraGX+Bxp9DIaU1W 1uJfb8L3N5PvDAA64TxEiwxsee/4RzvBOYVQ9Wack7rrfY1om52hRWQZBRLG9sdGYmd3uEx4cRKyu TY43Dx+bSfWKVNwUNjEbA***udkZk5ItOZjDCPDmKm3UJBw8ed LJmhJkzd16HdqTD/ChGG2sAMCy5JvX46aefLmIMbKivdK4hKFlGPgNZyU6dOtXt9+/fX2r07Nmzx+2ffPJJty/D77OqsAWjPtYv+P1zTntvth5Z//rrr7+6vY+tjwiJrR2g78JgARtsxqBexPosk4l5X2ydRCwu9cuf rsq5Jsoe2YSb0er8txtkUGfA0sdgYA4rtLjZbC7TXH9l864oFC pbaKnzn/BcV18uVFZWrvvgAfFvCGnTiFjdGzZu5uPxmtzNEbJ1PgcOHHB7 H1yD5tVB7lQ25nZ9w4Ayff755+53KHfDnnkOOzh+Ewb+c9EhxM N9zsI7H9LjHtQdSQwUzH3LCMuv1xhgraQd6XBN6jVrAPx2Vff5 6rsFc+4oqlAGGFeED2TDh3vIAIR7gPs57FeActnCQ39KLKfPqu Lo0aO90qQ/sCdwyFud9t5sPbL+FWMj7JdOnjxZ/LuFKXHurw9xfWVrI/EYeDfJs/9kEecjE/Jh5zIdg6wphy8D7gvpm16D3GumaEf+2w0yIL1ckk9JDCbodKio dMQ8W4qVzf/QisN65oYyouEc5vssLpWqTFm2Gxo47ivmDCkH+cPrwApWRqWUx SoR8SgHGx4f4tEoqYAcMzgHCxJDyKxjyk4HRueFrMDO5ZivyEL oSKhcrNLHcKDSA/+RM51nO4mVpxVwXWTsy8TK1EojqB3pcE3OZ6oD9yvzsiiNsDMe qPBaYPLL9AxrdGiTVudRfKkR2kCBwRMyp035/YrdB9oV94inFHxy+yybX6eeQNhHWV0iPc4HW2dEW85t762oR2G/BJYnH9KC8F0DZiRynEdW7bFVH+QNPOmBTOgvWeOFzK1c/pNQ9FksaieeycCXtV+/cq+Zoh35bye2rCC1xiRG9CmJwQadDpWfm4VbHKWC0E2hGVjBWH 68T4DGQFz2VG7c6mXKshNQeck3c6s0cvLHKARF7Hc4fjksHgqH c/0GYKMzjptbkBd6EI/4hPvn5rzsg6cOyI/Jmg3oLKwxtItYeVoB5fbrD14oDCPqBDJGefmjk/7SjnSoF9RzzuWa1GcULfWC+2qKZqBCh05eaYPWJq3O380pwjpw X2mPGAFWBspEO6ZdxBZQ5vZZnEc8lDnxUCgGipA0LT3qEPnwPY y57b0V9QgD3uoy57GRP38QA/SzKNXwmqQJVtbYZiAX8uzXGytX+MSN9asmA+JzXmjE1blmjHbl v118++23bj9jxgy3z+E/vB+6+C06CNYdljgdY7sVrRBCDCRwxTO6Zi3P3R6oDVXwbmEU1l lD9a/wMAxGGFnAfffd5/ZCCDFUYNSPd+3TTz8tQkQnYcCKt+r5558vQvKQwdBhcDkzB2+L jmw+TwghhhJMqbCWoBXTfaIeLK5nOqSud0cGQ4fhUSLmq7DumJ v05xuFEGKowFw96x1YLCg6B94F1sywjqYuWsMghBBCiErkYRBC CCFEJTIYhBBCCFFJ5ZQEHyNhgQTP59ozwCzU45ldXj7hP1/MYj7/WVOf1DnAWwx5vKPsuetYHOZieIOXPc/LqltezBFLw2CBDW9lIy+***l5SxkLEu2axOPLbjlrDXjpCXLyX xVqYTyL7L8jwSc8zx65jMGzusz78U4CnnuGsviGPb5paZXh59+ okpsQQoh/N6UeBp6V5WMkvFgChY/SYQMMg9TrUFl9aXHZWNwHZefUxZQkH37h+qTDi1JIY+PGjUWs3 pjS89+k5mPvAbdrsvGbsJwv0pXBt+LrlhsDyZcjGy9CsTwhA8B QCuPZhoEB9jpWXoUai4chALGnNqrkJoQQYgiAhyHG8ePHeyZNm tTzz2i959q1a0XoHQ4fPuyOr1ixogjp6enq6nJhZ86cKUJ6s2n TJnecvU94nRhhHPI1ffr0ngsXLhQht1i3bp2LS/6N7u7unj179rj4HGMjryFcn2P+NflNWJjnGHa+j4WxkbcY4XnI j/+xPIIdRwZlUOay6xjIZ+7cuU4+/DZy5SaEEOLfT9LDwIgYeFVl7FlN3OuMgCF35MwbpTiHZ2+bHbE zPYJrPpwqsNcH++8p/8e4ce+qh/A1pQZlwFWPd8S/Jr8ZfTf7vDDlZprjxIkTRUj/YSoCT0DZiB/57tu3z8WrmkLga3rIE9n4Uzk5chNCCDE0iBoMuLpRIFUvdmA9Q d2vT9o35M+ePev2/YXPKvN55VwoC+85T60jsE+tmuvex9z0sc+x5rJhwwY3PcDrUJs xPIzhw4cXv+Jg8PE2SV6OUgbTMLzzHYMm9g7zKrkJIYQYGkQNB vuwT0x5NsuoUaPcPvxSWas4ffq025thAoyw8W6UGT9WZsufT+p zrHUg7aVLl7prNPuiEgwOXrxh6xNCMPjwZmAE2MLIFLt27XL72 CtCc+QmhBBiaFC66DGmPFuFPXFhMB3AkxCpLQcWaTJ1wBRCK9+ gaIq5WSOHz6virSCPtmCxLngE3nzzTWd4LFiwoAjtjRlNVe8JZ 9oCuecYFkIIIYY2pQZDJylb6c9WhX39DIXMJ5gHKrYWIGdqgic +QsNp1apVznvAVEFsbQLXxCBBDlVGgH34Zf78+W4vhBBCpIgaD MOGDXP769evu307sHUBBo9EogBTWxm+sdDV1VVrTUUONhXRiik aPB8YQHhYWGxYBiP/0HBas2aN+yRs6pOkx44dc3tb/FkGhgWGWqe+vy6EEGLwEjUYxo8f7/ZVLvi9e/c2Fi9eXMu9bkZIqz7rvHnz5pYYC+PGjXP7mJFkckitGagLBhD5 ZbFhmey4D6HhxLRG2ZqCy5cvu/2MGTPcPgVTGxhCvNdBCCGEqCJqMDAKZuTJCLTs8cejR4+6R/uImwvnwNSpU92+GTAWyCPu+WY9C2PGjHH7mJFkjy+2cp7fnl7A 2GklTFdgjFTJ4ty5c24/duxYtxdCCCHKSK5hMIW2ZcuWqNGAssatztsQc1fR9+ecFLyG2o wF3PPNTkNwPlMAvNWS0bfBb1sz0EowPpAD8qh6VXMulm/KUYUZQVOmTHF7IYQQooykwcC8NvPlKBZeD71+/XqnpLdt29aYN2/e7YV1y5cvL864A6v0iWtbzjl1wICxb1YwTeCnZVt/nkJYvXq12/PaZfLMxm/SqHrioD8ghzremSrsyZOc6R7iUq5mDS0hhBBDg6TBAMyX79y50 z2myPcLUNLMu6NoWO1/6NChqMLBMCCubZzDokYMkNQ5dfBf+sS1/bRss/cq1IGpGMrLGyS5Lhu/CWvHuwiQQyvfoGjTKTmPw2IIjh49uvgnhBBClFP5tUohhBBCiF IPgxBCCCEEyGAQQgghRCUyGIQQQghRiQwGIYQQQlQig0EIIYQQ lchgEEIIIUQlMhiEEEIIUYkMBiGEEEJUIoNBCCGEEJXIYBBCCC FEJTIYhBBCCFGJDAYhhBBCVFL68akjR464T1Xv3r27CEnD56v5 8uK0adPcf87dvn27+x0yceLE29fcvHmz+7qlwTUWLlxY/LsF17ZPN/vnGpMnTy5+3YEvTFpe+NQ1n6k2/GN8CpuvW8aYM2eO+6w1n/dOcf78+eLXHazs4bEwrYMHD/b6CmZZPoHPevt54dPYx44dK/71BdmOGDGisXbt2iJECCGE6CcYDDGuXbvWM2nSpOJfOXPnznVx z5w5U4TEOXz4sIvHtWHTpk3uXIPzOU48Y8WKFW4ziM95huXTrh lixy1vlkZZXru6ulycFHZNP5+GHQvPD8seplGVz1iayMWXXwyO l5VVCCGEyCE5JXHgwIHGsmXLin9xGBEzurfRfxWMuvEg2Kj64s WLjSVLlrjfwGiaUT1eDWBETZwNGza4/8D5vkfi0qVLbqTtj9R9KAdeCRups+e/pRFCmngBGN2n2LFjh8tn6AkBjpGfENJDnpZPRv3EwxsBVfm0cv ppIhdkz31IgXy5thBCCNEMSYMBpTxr1qziXxwUEQoc13oVuMdD hYc7PaZ069Dd3d0YOXJk8a8vW7duzZpSMVD4vuIOQcFjxDBVEc KUw40bN3oZQblU5RM5lU0/pOA88oshJIQQQvSXqMGAUiwbtRsouByFj7LCAMlRpMQbP368+0 36KG+UuIGXgjDj8uXLTknj6bDNRu0xyhQ+I/XUMWP//v3OuxDKpsozMXPmTHfcFDfGBd6BCRMmuP8hZfk0Tp065fYp48Z AXhZXCCGE6A9Rg+Hq1aulo/a6oKxC70KMlStXunj+Ij0bdZsxgPLzR+IYC+SVBYZsKGyMitBo QFFzPsdiCh9w/5d5FzAoUPIxJc5iRX/KIYSy441h0SL5wHggvzHDoyqfQF64BtesApliWAkhhBD9JTklg ZJpFSdPnmzMnj27+BcHY4ERtT9CN+XJ6NwMAiDMwE3vGxAoe38 dhIHi9a/BkxcheDdIK4UZFKESx1uA0VL2NALl43zLA+WkHKFhk5NPjAUMl NQ6ihCelBBCCCGaIWkwtAqUPqPycePGFSF9MWMBJekrYzwTKGh fKTLXjzFTNu1QpSDxEJAnmx4AWziYmiIA8mjTJT4YRBzDADDvA JhBQDoc9xdvYtjgkQgNG59UPs2bgSyEEEKITpA0GFBUrYDV/ZBy8zOCNmMhBlMOKcwDYcreuHnz5m0PCcYICy59YmW7cuWKOyc 1BVBm+ODlMK8Am00T8Ns3dspkmpNPjA8zFuq8WwF5CCGEEM0QN RjGjh1bqqjrwFMMeAlioCQhZSzwlAZKE5e/gVIlDEWMcufaNqIHlCpTC7bOgCkG/vtGRWx9AEo1lU8w5V21wDBGLJ/khzUINgVSlU/C+Y8xUvdFTOQ95hkRQgghckm+6ZGRO/PsOQqS0TeL+WLxbdQcus/tnBiM9O0Rwli80MCwKQ2j6g2KKOEwP1wDpZpSxhgiPCGR82gjc VHuVflE+fseiLJ8IkcMihjhdXxMfqFMhBBCiDokDQYUlF4rPPj BeGGdRNk7HoQQQogqkmsYcOnjMheDG7wiscdAhRBCiDokDQbc1 yyus3UGYvCBl4i1E/1ZdyGEEEL4lH6tUgghhBAC2v4eBiGEEEIMfmQwCCGEEKISGQxC CCGEqEQGgxBCCCEqkcEghBBCiEpkMAghhBCiEhkMQgghhKhEBo MQQgghKpHBIIQQQogKGo3/AYZbeMfrEdsPAAAAAElFTkSuQmCC[/IMG]
                  4 Fuel Injectors Fit Yamaha F115 HP Outboard(2000-2011) CDH210 INP771
                  ( 172853774832 )
                  Delete item
                  Add note
                  ITEM PRICE: US $27.00
                    Hmm, seeing that boats.net gets $169 each for the factory originals, I suppose that you got your money's worth.
                    https://www.boats.net/catalog/yamaha...jection-nozzle
                      How can you type all this🙂
                        It's exhausting
                        But boats.net also gets $7.25 for a spark plug.....so there is that.
