1990 30 hp 3 cylinder shift cam assembly
    The shifter pushes down or pulls back up to change gears.
    in most newer motors they twist to shift
    My C40TLRX has the rotate/twist type so I do not know how to install yours.
      It definitely does push down and pull up to shift. Do you know how to install it once the bearing carrier has been pulled? I still can't find this information. Thanks in advance.
        looking at the parts breakdown it has a spring and a pin(plunger) inside the hollow part of the prop shaft.
        So my guess would be to install the shift shaft/cam assembly before sliding the prop shaft in just like all of the rest..
        the spring will push the pin/plunger too far for the cam to slide in front of it when the cam is pulled out.
        But then Walleye said he has done it before
        • #19
          Thanks again. I'm gonna give it a try soon.
          • #20
            If you are able to to pull the carrier out part way with the prop shaft you can install the shift slide.
            • #21
              Pulling the carrier part way and NOT replacing the O-Ring seal (between it and the case) sounds like a potential leak fixin to happen...
              Especially with the age of the engine.
              I did a Sazuk 140 (had to weld up a cracked LU case) and re-sealed the carrier with a new o-ring.. If I had to partially remove that carrier, I'd pull it all the way, clean and re-seal at least that end of it.. That'd be the time to do it...
