Yamaha F80b water pump
  • Yamaha F80b water pump
    Hi!
    i recently bought a Yamaha f80 and i have replaced the water pump and i am wondering if its supposed to come water out where the speed hose runs out? See video.
    Look's good to me.
      that is a lot of water, but I never looked at a F80B idling on a hose before so nothing to compare it with.
      are you sure you got all if the seals into the pump where the up pipe goes ?
      maybe the rubber seal got pushed out of place when stabbing the lower unit back on.
        Cant find any rubber Seal between waterpump and cooling pipe. Should there be?
          What year is it? Outside the US?
            I can imagine that I see a "Damper, water seal" in the photo above
              Europe, F80B 2008 model
                I think the water Seal is inside the pump housing. So i guess is ok. I have a solid tell-tale
                  No. According to what Fairdeal posted you appear to be missing the bushing/seal.
                    Edit...I canít tell if the seal is under that plate or not. Maybe remove the screws and have a look.
                      the water pump kits I get include the pipe seal,
                      did you put a new one in?
