Can I add trim lift to 1991 C40ELRP outboard
  • Can I add trim lift to 1991 C40ELRP outboard
    Does anyone know if the trim lift kit 6h5-43840-05-EK can be used on the C40ELRP engine? If not, are there other trim kilts that could work. From the diagrams I saw, the parts all seem to match.
    That trim unit is nla new.
      I found a used one if that kit will work
        I can not tell you that for sure, Boscoe may.
          a manual tilt electric start motor, probable has different parts on it beside the T&T Cylinder.
          Maybe Someone can comment on that also
          If it was mine I would be looking for a aftermarket T&T unit to bolt the motor onto
            What kit?
            6H5-43840-05-EK is the power trim and tilt assembly. Just a part.
            https://www.boats.net/product/yamaha...h5-43840-05-EK
              I would think so. Clamp brackets, swivel bracket, wire harness, relays, and a few other doodads.
              As you suggest, I would go with the CMC power trim and tilt unit that mounts to the transom and that holds the motor.
                Panther Marine is another manufacturer for a T&T unit. That'd be the way I would be looking into, as well.
                  I like the Panther model.
                  https://3989ac5bcbe1edfc864a-0a7f10f...ansen_copy.pdf
                  https://www.basspro.com/shop/en/panther-by-marine-tech-model-55-trim-and-tilt
