I bet Panasonic has the answer
  • I bet Panasonic has the answer
    Regarding mixing hydro fluids. I have some new mil spec 5606 in two brands. Aeroshell and Phillips 66. Would there be a problem mixing them in a hydraulic steering system. I don’t think I have quite enough of either to fill the system.
    Perfectly acceptable.
    In most all instances it is the specification that is given for a product to be used. The brand is irrelevant. Normally the brand won't even be specified. Which is why Seastar says to use 5606 without mentioning who is the supplier of the 5606.
    Are the two products the exact same specification? There are several generations of 5606.
      What kind of oil should I use in my SeaStar system?
      Recommended oils for your steering system are: SeaStar Fluid, P/N HA5430 (1 quart), HA5440 (1 gallon). The following brands are acceptable: Chevron® Aviation Hydraulic Fluid A, Esso® Univis N15 or J13, Mobil® Aero HFA, Petro Canada Harmony HV115 (in Canada only), Shell® Aero Fluid #41, Texaco® HO15 and other fluids meeting MIL SPEC H-5606-G.
      http://www.seastarsolutions.com/supp...ering-systems/
      5606G-G has been superceded by 5606-H. Seastar has not updated their website.
      https://www.google.com/search?biw=10....0.ixjjPCFQD4w
        Mix away..Mix away.
        I hate the smell of 5606 that comes out a
        grey murky mess from oleos. Nice and red when it goes in and stinking mess when it comes out..
          Both brands are the -H version. Thanks!
            Mix away..Mix away.
            It is a wonder that planes still fly, cars continue to steer and brakes still stop. The stuff is absolutely disgusting when the systems are purged. Pus.
              What is contaminating it to make it like that?
                Apparently the stuff attracts water. Fill cap is vented....On the Seastar system.
                  Then if it can attract water should the entire system be drained periodically and fully replaced and if so how often? My Sea Star I am not sure it is vented? I thought they made vented and non vented?
                  Dennis
                    Not sure about vented/non vented. Believe my cap is vented.
                      The helm pump should be checked periodically (say once a year) for the proper quantity of fluid. If it starts out bright red (5606) and then starts to look or smell funky, I would change it then. Same with Seastar fluid but it will be amber coloured I believe. Watch for any colour change or smell change.
                        Vented cap part # HA5431 non vent part # HA5432. They both look basically the except the non vented cap is not open on the inside of the cap.
                        Dennis
                          Hmmm. Don’t know what I have. It is a brand new cap. Rebuilder dude replaced my old one.
                            I got the steering system hooked back up, filled and bled of air. Flushed the lines and cylinder. Actually removed the seals on cylinder and swabbed the inside with a plastic pistol bore cleaning rod with cloth. Hope that all the sediment is gone for now. Steering is smooth as silk once again.
