Starter on P200TLRW 200VMAX
  • Starter on P200TLRW 200VMAX
    when I go to start it dims lights and stalls out my electronics. Batteries are less than a year old and fully charged. I put a voltmeter on it and turned the key and voltage dropped to 3 votlts as it was turning over. At $600 has anyone had one rebuilt or am I missing something else?
    It probably is not the starter motor at all. It is probably voltage drop. Due to corrosion within the battery cable or at the battery cable connections.
    Get a scotch brite pad and start cleaning up every connection point between the battery and the starter motor. Including the ground connection points. At all connections along the way.
