Skeg
  • Skeg
    I need to find a new place to order skeg's, i have been getting them from skeg depot i think
    they closed the doors. I need the smooth aluminum not the cast.
    TH Marine pg 17 of catalog maybe
      T and H skegs are to corse of a finish. I want a smooth finish.
        Thank u anyway
          skeg depot website says they cast theirs themselves, so it sounds like they are cast also
            start with 40 grit on a random orbital sander',the weld will need some finishing anyway, won't it? Or cut one from a failed gearcase.
              Customer wants a new one. Skeg Depot finishes there skegs off, i finely got a hold of them.
                who do you use to weld them on?
                  skeg depot's look pretty slick, i see why you want one, good source!
                    Just me, i have welded aluminum for 26 years. I was certified before i started outboard repair.
                      Originally posted by TownsendsFJR1300
                      Will a Skeggard work for you?
                      These work great, I did exactly the same.
                        I have used skeg depot alot just didn't answer the phone this last time.
                          Good people
                            OK now I need an explanation of the drain in the rear.
                            what is being drained out of the skeggard
                            and OJ's glove did not fit real well from what I remember
