F115 washer corrosion
  • F115 washer corrosion
    Should I be worried? They are the washers of the bolts holding the bottom cowling on the exhaust guide if I'm correct (90387-08M37-00). If that's the one it seems the power unit have to be removed to replace them.
    My 2006 F150 has the same thing.
    I haven't touched them and don't plan on it..
    I guess you could wipe a little bit of water proof grease on it, but I wouldn't loose sleep over it.
    BTW, a parts diagram LINK and then the part # (from the diagram) is MUCH more useful for us on the other end of the computer.
      and my "2005" F225
      aesthetically annoying, but otherwise not a concern.
      (And yes, non-trivial to replace)
        ok thanks, I will deal with it the day I have to remove the power unit, hopefully as late as possible..
