Oil filter bracket
  • Oil filter bracket
    can someone tell me what the allen headed screw is for in the side of oil filter bracket. Appears to be leaking a little...thinking about pulling it and putting some 518 on it.
    Yhis is on a F150
      still not enough info
        Right below the oil filter...
          this?
          I imagine its a simple plug, an artifact of the machining process for the casting.
          safe bet when you remove it with a filter in place, you will have the filter contents running out
          suggest you wait for an oil change for your "removal/sealing" job
            I was shooting for what F150.
            I traded in my 2000 F150 when I bought my new 2014 F150 ford PU
            Knowing exactly what Yamaha motor you are taking about usually help others know a little more
              That would be an odd leak. Unless someone decided to unscrew it out of curiousity. Are you sure the oil is not remnants of a previous oil change?
                Ha, i was talking about a F150 on a Yamaha forum...how did a Ford get into the conversation?
                  Your F150 Yamaha has ford parts in it.
                    always give the info on motor so everyone knows exactly what motor you are talking about.
                    which of these Yamaha F150s is yours, if it is a 2006 and later?
                    https://www.boats.net/catalog/yamaha...nd-later/150hp
                      Wouldnt doubt it the way the port motor leaks oil!
