"Check Engine" on Guage
    typically it takers about 15 seconds to get the code to display.
      ????? What?????
      Below is from a VZ200/225/250/300 Owner's manual with reference to funtionality of the conventional multi-function tachometer.
      Someone slept while in the school house it appears. Now it won't display codes but it can display a check engine icon.
      I thought he said he had the square CL gauge
        The OP did. I was responding to rodnuts comment that only Command Link instruments have a check engine function.
        • #19
          No codes from the Capt. Obvious method. I'll try the software after I digest the manual for YDS.
          So no known past occurances with "Check Engine" flashing on square guages?
