f225 txrd high idle
  • f225 txrd high idle
    My engine is starting to idle at or around 900 -1000 out of gear. If i shut it off and start it again once or twice it might go back to 700. Smells rich and I'm lost. Any suggestions?
    that you are ECU telling you it is unhappy with one of its inputs.
    (Did you happen to have removed / replaced the intake silencer assembly recently?)
      Yes, about a month ago and I just did put a starboard side thermostat in.
        well, forgetting to replace this wiring connector will cause it -
        but so can disrupting other sensor wiring
          Thanks fairdeal. It's connected.
            were all the throttle link updates done? typically if the ECU is not happy it fixs base timing at about 10* BTDC. it may be time for a session with YDS. DO NOT shift gears at that speed.
              Rod bolt, I'm not sure. I just purchased it a few months ago. I'll have to call up and have them run it. I know that a Yamaha tech on Kent Island in Maryland took care of yet. But yes I need the yds. I have a mac book so I'll have to find a normal laptop.
                ah right
                2002~2005 F225, LF225, F200, and LF200
                FACTORY MODIFICATION CAMPAIGN - THROTTLE LINK RODS
                Yamaha Technical Bulletin O2004-010
                Given that the problem seems to be described as intermittent,
                I suppose that "mechanical" issue is more likely that a "bad" or disconnected sensor
                Keith, you can call Yamaha Cust Service in Georgia - 866-894-1626
                and they will look up to see if the recall was done on your engine
                  Thanks again Fairdeal. Yamaha told me today that the recall was not for my f225txr. I started laughing and thought of Rodbolt. Not all 2005's are 2005's
                    well at least a timing light should show if it is hitting the 10 BTDC
                      I hooked up the YDS the other night and had a shift position and oil pressure sensor. I cleared them and then the shift position came back. The iac was 67%
                        go over to the screen labeled diagnosis.
                        if a signal is bad or irregular and active it will be at the top and high lighted. stored codes will tell the engine hour it got stored.
                          It's showing irregular and had a stored code for the shift position. The throttle linkage has the bumps on the top. I don't get why it's idling crazy. Start up the engine cold and it idles at 600-700. Shut it off while at 150 and start it again. It can idle at 1100, 900, 800,or 700. At 600 and 700 the timing is around 2 degrees and at 900 and 1100 it's about 9 degrees. Thats whats showing on the yds. The engine will reach 6000 at 50mph.
                            cause anytime the ECU aint happy it is trying to tell you. listen to it.
