Hi Guys, I've had the driveshaft seal and impellor replaced about a month ago. I still have not installed the lower unit back on the motor. I'm in Canada and spring refuses to show up, so it might be a few more weeks before I install it. When I removed the unit, I left it in neutral. This is my concern: The shift rod in the lower unit will rotate a little over 180 degrees and no matter where I position it, the propeller is always engaged in the forward position. I can never find a spot where the prop spins freely. Is this normal? I rotate the driveshaft by hand and I put the shifter from one extreme to the other and the prop is always locked in forward. It was working perfectly fine before I removed it and I just don't want to mess anything up.
C60TLRX Shifter Position
that lower unit is one that is spring loaded into forward so you will have to overcome spring tension to get to neutral and reverse.
the shift shaft can turn 360 Degrees, so turn it until you feel it get to the neutral detente and it stays there along with the prop being able to free wheel
ÂÂÂÂÂÂ
