Fairdeal my tired mind needs help
  • Fairdeal my tired mind needs help
    F225TXRD with a -30 ECU. Motor has the CL connector. According to Yam data no joy on it being CL compatible.
    Doesn't the -30 output some CL data? The -31 has full CL data correct?
    Damn if I can remember all of this stuff.
    I can't remember either - if I didn't have photos and notes stored on the 'puter I'd be completely in the dark.
    But checking back, you are absolutely correct.
    My TXRD was built with a -30 ECU - but had the CL connectors on the harness (but no yellow tape, no "S"/"W" labels)
    When I connected it to my Garmin 740s I got almost all of what I was hoping to get - certainly fuel flow, which was my major interest
    (can't recall what was NOT there - no engine hours? maybe no temp ? or was it oil pressure?)
    I got quite a few happy months of use from it
    but the problem came after Garmin updated their OS firmware -
    after I installed one particular update, suddenly the communication connection went haywire
    it would show up as connected, I'd get data, then the Garmin would "drop" the Yamaha - was on a 30 seconds on, 1 minute off cycle or similar
    made it impossible to use
    so that's when I bought the -31 ECU : perfect.
      Thanks. I try to store stuff but can't remember where it is all stored.
