F350 Trouble Code 162
    there is not much that is field servicible inside.
    if your getting two blue indicates troubleshooting is useless as it is working correctly.
      Yes, 2 blue lights are present and works correctly until a jolt throws the code.
      Do I have to replace the whole thing??
        can you make it repeat?
        if so tap on it while using YDIS as an engine.
        the 2.22 version can act as a helm or an engine.
        • #19
          I would like to see these later versions of YDIS. Walleye, do you have the latest version?
          • #20
            No I do not, perty much have to have a dealer number to have it.
            • #21
              There are lots of parts within the DEC box that while not field serviceable are certainly available for replacement.
              The average Yamaha Master Technician might not be up to the challenge of opening up a DEC box, replacing components and then getting it all back together. Ever heard the saying about putting ten pounds in a five pound sack? It won't be for the feint of heart.
              In aviation this kind of a part would be sent off to a shop that is trained and equipped to perform a repair. I doubt there are any such shops here in the US for the Yamaha DEC box.
              • #22
                • #23
                  So is there anyone that repairs the control box... I don’t have YDIS 2.2.
                  is replacing the best option? What’s the current part number?
                  • #24
                    What would the YDIS tell us about this mess? You sure that is not an ETEC diagram?
                    • #25
                      • #26
                        I guess I aint the average tec.
                        I have had a few apart.
                        if you make the attempt go ahead nd buy to correct size carbide drill bits for the screws.
                        most will snap off and TiN coated wont touch them.
                        it aint much harder than a 703 box.
                        • #27
                          I’m not taking that box apart.
                          what part number do I need to buy, and is it a direct swap? No programming required right?
