93 70hp intermittently won't rev past 2400
  • 93 70hp intermittently won't rev past 2400
    After extended idle, my 70hp takes off fine, but after about 30 seconds losses power and will not pull past 2400rpm. After shutdown and cooling off, it seems to work fine. Any ideas?
    That engine has a overheat warning that will sound buzzer and reduce RPM,s to about 2000 RPM,s, if the buzzer is not working it may going into overheat mode
