HELP! Non Command Link Gauge with command link system????
  • HELP! Non Command Link Gauge with command link system????
    Hey guys, thanks in advance for any help I receive. My question is this. I have an old style round fuel management gauge (yamaha). I'm trying to install it on a boat with a brand new f-150 with command link. Is there a way I can use this older gauge with this newer command link motor? If so what do I need? All I have is the gauge, no harnesses or other components.
    No, the Command Link speedometer has the fuel management functions, if you have the speedo you shouldn't need a separate FMM gauge.
      sorry i didnt make it clear. All I have is the command link tach. No speedo...Trying to get fuel management and i have this older yamaha gauge already, and wondering if i can use it on my boat.
        You would have to install an analog gauge inverter(MAR-ANLGI-NT-08) and the rest of parts needed that you missing from the gauge you have, the fuel flow sensor and wiring harness's.
          would you happen to have the part number for the wiring harness and flow sensor?
